Can you tell...
No tech discussion, please
Thunderfoot
Re: Can you tell...
Post by Thunderfoot »
Yep, I changed out the Amp gauge to a Voltage gauge :thup: :D I installed it in the stock housing and just used the face so that I had the voltage increments so it looks stock. 8)
Now I wont get stranded if the alternator dies again :doh:
I'm going to work on upgrading a stock cluster this way and if all goes well maybe I can peddle them.
Shayne
papabug71
Re: Can you tell...
Post by papabug71 »
Very slick!
Matt
1971 F-100 Sport Custom - My grandpaws truck
Been in the family since 10/3/'71 (Brand spankin' new)
Mine since 5/7/'94
302 / 3 speed / 3:25's
--Currently undergoing full frame off resto/mod--
smclaren
Re: Can you tell...
Post by smclaren »
Put some oil in that beast, TF !!! :lol:
Image Steve - Caloundra, QLD, Australia Image
1969 F100 4x2, RHD, Base Model, 240ci, 4sp, Dealer Canopy, No Bloody Radio.
willowbilly3
Re: Can you tell...
Post by willowbilly3 »
Well, I did see that you had a volt meter too. I tried some regular old SW guages in an F600 dash plate and found the holes to be smaller than a standard gauge. What did you use? I like the thing you did with the volt meter face. Now get the F600 tach face on an electronic one. If you need another stock gauge cluster, I have one from a school bus. The dash plate itself seems to be much different on a cowl and chassis than from the regular cab F600 but I think the gauge cluster is the same.
Thunderfoot
Re: Can you tell...
willowbilly3 wrote:Well, I did see that you had a volt meter too. I tried some regular old SW gauges in an F600 dash plate and found the holes to be smaller than a standard gauge. What did you use? I like the thing you did with the volt meter face. Now get the F600 tach face on an electronic one. If you need another stock gauge cluster, I have one from a school bus. The dash plate itself seems to be much different on a cowl and chassis than from the regular cab F600 but I think the gauge cluster is the same.
I took the guts out of a new gauge and put/modified it to fit in the old stock gauge housing. :) It works really slick, only thing is the volatage gauge is so sensitive and the truck wiring so under rated, that when you turn on the turn signals the gauge shows the voltage drop with each flash. :lol: still better then the worthless amp gauge. 8)
I'll send you a PM on the cluster you have.
Thanks for all the comments everyone! I'm glad this worked out where it doesn't stick out and looks pretty stock. I like this instrument panel as it is a little easier for my tallness to see all the gauges better and it just looks 8) too. :D
Shayne
bobbyinpd
Re: Can you tell...
Post by bobbyinpd »
Next bump I get I want to do these gauges for sure....
1996 F350 4 Door Dually Long Bed Power Stroke Diesel - K&N FIPK Intake, MBRP 4" Straight Exhaust, Diesel Turbo Lifesaver Turbo Timer, BriteBox.
1990 Escort 1.9L Stock
1958 Bel Air 4 door - FOR SALE
1975ish Camaro Autocross Car
1973 Camaro RS awaiting cage,backhalf, and 498 BBC
1969 El Camino - Wife's car
2004 Carson Trailer-to haul the goods!
www.bobby77.com
willowbilly3
Re: Can you tell...
That sounds like those old Mopars with everything run through the amp gauge, they would flop the needle like that.
papabug71
Re: Can you tell...
Post by papabug71 »
That sounds like those old Mopars with everything run through the amp gauge, they would flop the needle like that.[/quote]
I been that route on my Duster. The best thing you can do is wire around the amp gauge & run a aftermarket volt meter.
Matt
Mine since 5/7/'94
BobR
Re: Can you tell...
Post by BobR »
Hello Thunderfoot
I see you are in Boise. I'm in Lowman about 1 1/2 north/east of you. I'm about to try and installed the same type of instrament cluster (F600). You said you reset the speedometer. Can you explain to me how this is done. Any help would be appreciated.
Thank You.
Bob R
flyboy2610
Re: Can you tell...
Post by flyboy2610 »
aramil wrote:the steering column isnt straight.... :o :?
The steering column is offset in all our trucks. It's designed that way from the factory.
Red Green
you'd better be right.
Calfdemon
Re: Can you tell...
Post by Calfdemon »
They TF,
What brand/style gauge did you buy to gut and mount in the F600 panel? Was it easy to do and how did you mount it in the F600 housing once it was out of it orignal casing?
I am tempted to do this as I do not like how my F600 gauges (gas, oil, temp, amp) are reading on my F600 cluster after my conversion. I really like what you did and am inclinded to do something similar, but I want to make sure I do it right the first time so I dont have to buy gauge after gauge from breaking them or getting gauges that wont mount propertly. I really like the look of the Auto Meter Old Tyme Black gauges as a replacement, but I am afraid to buy them and start pulling them apart only to find out they will not work for what I need. What is the make of your Volt gauge?
Thanks in advance..
-Rich
Current toys -
Former toys -
Thunderfoot
Re: Can you tell...
Calfdemon wrote:They TF,
Thanks in advance..
Sorry for the late reply, somehow I missed this as I was working out of town all summer without my computer. :oops:
Basically I took and used the stock gauge housing by carefully pulling it apart and then putting the new gauge guts inside of it. I had to do a little filing on the stock face plate to clear the needle and some on the housing and cluster for the terminals width to clear, and shimmed the depth of the new guts up a bit to make it the same as the old ones.
I just used a cheep gauge similar to this from Shucks/Kragen/.... parts store http://www.oreillyauto.com/site/c/detai ... &ppt=C0134
PM sent. :wink:
Shayne
hazelnut
Re: Can you tell...
Post by hazelnut »
Thunderfoot, The difference i noticed is the first pic can be seen without being logged in, The second pic just says i dont have permission to view. Logged in just to see the differences LOL.
wobblefoot
Re: Can you tell...
Post by wobblefoot »
Thunderfoot,I have the same gauge panel I want to put in my 69 F100.Did you have to change the plug or was it direct plug in?
69 ford f100 Longbed restored 360,auto
71 ford f100 302 3spd shortbed my daily driver
Mancar1
Re: Can you tell...
Post by Mancar1 »
I can tell you what is wrong with your gage panel :? Its not in my truck. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
