Can you tell...
No tech discussion, please
Thunderfoot
Can you tell...
Post by Thunderfoot »
...what is different in this picture :?
Both pictures are the same I just uploaded them 2 different ways for some to see... :wink:
Shayne
Re: Can you tell...
the size and the way it opens up when you click on them. i use photobucket when the attachments are too large to upload here.
Re: Can you tell...
Yeah, attachments seldom get clicked by me, I want to see it on the main page, not have another window open that then need closed. PITA factor...
Jamie
willowbilly3
Re: Can you tell...
Post by willowbilly3 »
The gauges are not the stock F600 but aftermatket which means you probably had to open the holes up a little. And the engine is running but you just started it and it is already almost out of gas plus the truck only has 98 miles and you alreasy lost the wiper switch and drilled another hole in the dash. ????
aramil
Re: Can you tell...
Post by aramil »
the steering column isnt straight.... :o :?
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
warponyxlt
Re: Can you tell...
Post by warponyxlt »
looks dam good though :D
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
Thunderfoot
Re: Can you tell...
fordman wrote:the size and the way it opens up when you click on them. i use photobucket when the attachments are too large to upload here.
Nope, I used photobucket for the first picture... I only put it both ways as there are some that can not see anything that is from Photobucket (probably has to do with work firewalls)
Ranchero50 wrote:Yeah, attachments seldom get clicked by me, I want to see it on the main page, not have another window open that then need closed. PITA factor...
Jamie
There are some that can not see anything that is from Photobucket (probably has to do with work firewalls) so that is why I did the local attachment. The local attachments are local to the Fordification web site. I posted the same picture both ways so they could see and play along... Look closer but willowbilly is getting warm. :thup:
willowbilly3 wrote:The gauges are not the stock F600 but aftermarket which means you probably had to open the holes up a little. And the engine is running but you just started it and it is already almost out of gas plus the truck only has 98 miles and you already lost the wiper switch and drilled another hole in the dash. ????
Willowbilly, You are very close but 90% of the gauges are the stock gauges and I didn't have to modify the holes any. (Look closer here :wink: )
On the other things you pointed out the wiper switch got moved to the F600 location, I did reset the odometer when I originally installed this IC, the other hole in the dash was PO work :doh: that I will fix someday... Yeah, it's an FE its always out of gas :lol:
Here is a picture of it when I installed it the first time.
And here is one that shows where the wiper switch went to, it was also upgraded to Intermittent wipers at the time :D
Shayne
aramil
Re: Can you tell...
Post by aramil »
hmm... so it has to do with the gauges themselves.... new faces on the old guages? :?
Merlin68F100
Re: Can you tell...
Post by Merlin68F100 »
I like the look.
"A point in every direction is the same as no point at all."
The Pointless Man
thebannister8
Re: Can you tell...
Post by thebannister8 »
cool looking interior...i like that
Thunderfoot
Re: Can you tell...
aramil wrote:hmm... so it has to do with the gauges themselves.... new faces on the old gauges? :?
:no: not quite...
I will put the before and after pictures together here so it is maybe easier to tell.
Before
After
I'm off for a bit, I'll check back later today to see who figures it out. :thup:
Shayne
aramil
Re: Can you tell...
Post by aramil »
i found it!!! :roll:
now i feel stupid, its the alt meter thingy above the oil pressure guage lol.
warponyxlt
Re: Can you tell...
its the alt gauge backing it is different
69bumptruck
Re: Can you tell...
Post by 69bumptruck »
Alt gauge is different, and in the second pic, the truck is running. Look at the oil pressure & fuel gauge (dude, you need to get some gas) :wink:
David, owner of:
1969 F100 SWB (restoration in progress)
http://www.cardomain.com/ride/2317125
papabug71
Re: Can you tell...
Post by papabug71 »
The ALT gauge has been switched to a VOLTAGE gauge.
& It looks to be charging nicely. :wink:
Matt
1971 F-100 Sport Custom - My grandpaws truck
Been in the family since 10/3/'71 (Brand spankin' new)
Mine since 5/7/'94
302 / 3 speed / 3:25's
--Currently undergoing full frame off resto/mod--
