Both pictures are the same I just uploaded them 2 different ways for some to see...
Nope, I used photobucket for the first picture... I only put it both ways as there are some that can not see anything that is from Photobucket (probably has to do with work firewalls)fordman wrote:the size and the way it opens up when you click on them. i use photobucket when the attachments are too large to upload here.
There are some that can not see anything that is from Photobucket (probably has to do with work firewalls) so that is why I did the local attachment. The local attachments are local to the Fordification web site. I posted the same picture both ways so they could see and play along... Look closer but willowbilly is getting warm.Ranchero50 wrote:Yeah, attachments seldom get clicked by me, I want to see it on the main page, not have another window open that then need closed. PITA factor...
Jamie
willowbilly3 wrote:The gauges are not the stock F600 but aftermarket which means you probably had to open the holes up a little. And the engine is running but you just started it and it is already almost out of gas plus the truck only has 98 miles and you already lost the wiper switch and drilled another hole in the dash. ????
aramil wrote:hmm... so it has to do with the gauges themselves.... new faces on the old gauges?
