back-up light switch
The wiring harness on my 1970 F250 looks like its been messed with at least a couple times. The back-up light turns on and stays on as soon as I turn on the electrics. I traced the wire from both back-lights to under the dash but it looks like it was connected to some other wire I have not been able to trace-on (which does not correspond to the diagram). Anybody know where the the back-up light switch is located on the truck, i.e. where ultimately the wiring should end?
Thanks!
Thanks!
Re: back-up light switch
Depends on what transmission you've got. If you've got an automatic, then the back-up light switch is built into the neutral safety switch, which is located at the base of the steering column inside the cab.
If you've got a three-speed manual with column shift, it'll be the switch at the very end of the column in the engine bay:
(Sorry for the bad pic, it's the only one I have on hand right now.)
If you've got a 4-speed, then the back-up light switch is mounted on top of the gearshift cover:
Thanks for the response! I have a 3 speed automatic - so I'll check the location you mentioned for that case.
- Lar4t9r
If you don't mind, may I hijack this thread?
I have a C4 transmission in my '69 f100 that PO converted from column to a B & M floor shifter. He did not make any provision for backup switch or neutral safety switch. I want to add these but have not found any info on how to do it with this setup.
Any advice?
Any advice?
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
the dentside trucks had athe nss on the transmission. you might be able to find one of those and put it on your transmission.
- Lar4t9r
Well, I have been searching for this, but all I can find that mount on the transmission are for manual, not automatic. All the automatics I've found mount on the column. Anybody happen to know a sorce for a transmission mounted switch for C4 automatic?fordman wrote:the dentside trucks had athe nss on the transmission. you might be able to find one of those and put it on your transmission.
i had a 78 that had that switch on it. the transmission was a smallblock c6. all o fth ecolumns i have taken out of dentsides up to 78 have had the column nss on them. i would check with the vendors abotu a nss for 78 and 79 trucks and broncos. they aslo used that switch on cars. i don't know which cars or what year of cars.
- Thunderfoot
For a C4 look for one for a Mustang! My 68 stang has the switch on the transmission.
here is a link to Mustangs Unlimited showing the Neutral Safety Switches... http://www.mustangsunlimited.com/keywor ... &x=13&y=13 these will have the 4 wires on them for the reverse and neutral wires so you can wire it into your trucks wiring with no problem.
Shayne
- Lar4t9r
Thanks, guys...That should work.
or for just a reverse light you coul dmake a bracket that is close enought to where the lever kicks in a switch when you put it in reverse.
- Lar4t9r
I am concerned about the safety of not having the NSS...so want to have both backup light switch and NSS.fordman wrote:or for just a reverse light you coul dmake a bracket that is close enought to where the lever kicks in a switch when you put it in reverse.
