Holley carb?
Frankenstein
Holley carb?
Post by Frankenstein »
So the 390 in my wifes truck decided that it hates AFBs. I did a compression test because it sounded like a dieing motor and the comp was about 118 all the way across the board with zero leak down. I feel way better :woohoo:
The problems started after I put in the points eliminator kit (works great!)and new plugs. The timing actually stays in one place at idle now, I have it locked at 12* dead on, the vac advance pot on the carb works but the damn thing wouldn't tune right with a new Eddy 500 and a rebuilt Carter 650 both ran like total crap and huffed blue smoke out the exhaust after the points went away. Just for shits and giggles I grabbed the Holley 390 that was sitting on top of the slant six in the 48 chevy. I put a quick change vac secondaries and electric choke on it awhile ago but never rebuilt it after getting the carb for 20 bucks at a swapmeet.
It works great (still huffs some blue smoke) it runs smooth and has the power back. So now I am convinced that I have one of "those Fords" that is picky and hates AFB carbs and will only like Holleys even tho I'm not the biggest fan. So I have this other Holley sitting on the shelf that came from who knows where and it is the only one I have with the Ford kickdown linkage but I need to know what cfm it is and what it came off of so I can get a kit for it.
Here are the numbers...
Air horn- List-4452-1 with 0898 below that.
Top main body on the pass side- 6R 3059 B
Top of metering block- 6557 with 44521 below that
The jets are 66 (look new) and it needs a power valve (missing)
How should I set this carb up for this motor? Stock rebuilt 390 with a Eddy streetmaster intake, C6, not sure what gears, wifes daily driver.
flyboy2610
Re: Holley carb?
Post by flyboy2610 »
If I read my book right, you have a 600 CFM 4160 carb. Should be just fine for a stock 390.
The Holley Renew kit no. is 37-119, and the Holley Trick Kit no. is 37-912. The power valve no. is 125-85.
Hope this helps.
Red Green
you'd better be right.
Frankenstein
Re: Holley carb?
Thats what I needed, Thanks. :fr:
Joshpow
Re: Holley carb?
Post by Joshpow »
My 302 hates Edelbrock too, so don't feel bad. I gotta get the stuff to fix my 600 cfm Holley.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
Frankenstein
Re: Holley carb?
I got it rebuilt the other day, it runs great with lots of power. I am just not a fan of Holley carbs for daily drivers but at least it isn't a friggin Demon P.O.S. Those are by far the crappiest carbs on the planet next to Predators! Thanks for all the info guys!
flyboy2610
Re: Holley carb?
I Looked up the carb in a different book, and it's application is listed as a '68-72 FE engine, emissions carburetor. So it's actually made for the application your are using it for.
Red Green
rubiranch
Re: Holley carb?
Post by rubiranch »
Not only does your FE hate AFB "type" carbs so do I. :lol:
:fr:
72 F-250 CS XLT 390 C-6 4.10 40k miles
You don't shoot to kill, you shoot to stay alive.
I don't carry because I have to, I carry because I get to.
http://www.fordification.com/galleries/ ... ?album=514
