quote="mrsnicks"]
michael69 wrote: Look at it this way if it did not make a difference in your braking why go though the trouble to swap to disk
Because all the cool kids are doing it?
Patrick[/quote]
...but the nerdy kids go through the trouble to do it right because they actually know what they are doing.
Well, I don't really consider myself "nerdy" and I'm not the foremost authority on brake systems and I don't know everything there is to know about all Ford brake systems but, by the other side of the token, there is a lot I do know about them and their function.
Most of my front disc brake, or 4-wheel disc brake, conversion experience has mostly dealt with early model Mustangs. I've converted my own Mustangs as well as I have done disc brake conversions (for hire) for a number of other people who have brought me their cars.
The following photos shows some of the disc brake work I have done. This isn't intended as a 'plug' for what I have done/do, especially since very little of what works on an early Mustang will not work on an F100. It is for reference to illustrate and back up that I do have some idea of what I'm talking about when it comes to Ford brake systems.
This blue '65 Mustang belongs to a friend of mine. In 1996, I had removed the front drums and replaced them with Granada front discs. In late 2001/early 2002, I had designed some adapter brackets to adapt Lincoln Mk VII rear discs to Ford 8-inch & 9-inch small bearing rear end housings. My friend agreed to let me use his '65 Mustang as a 'test mule' to see if the adapters I made would work.
Rear drum on the '59 Ford Fairlane small bearing 9-inch rear under the '65 Mustang.
Process of installing the adapters I had fabricated and the installation of the 11-1/4" ventilated discs.
1.
2.
3.
4.
5.
In late 2003, I began work on designing some rear disc brake conversion brackets that would adapt '94-2004 SN95 Mustang V6/GT 10.5" solid rear discs & 11.65" ventilated Cobra rear discs to the older Ford 8 & 9-inch small bearing rear end housings. In the fall of 2004, a friend loaned me his '65 fastback, as a test platform, to check these brackets out on.
1.
2.
3.
4.
5.
6.
Cobra rear 11.65" disc
1.
2.
3.
6061-T6 billet aluminum adapter bracket I was working on to adapt 13" Cobra front rotors to an early Mustang/Granada disc brake spindle.
1.
Fitting the Cobra front disc brake components on my '68 Mustang.
1.
2.
3.
4.
'87-'93 2.3L Fox Mustang brake booster I adapted to fit on the firewall of a '65 Mustang fastback with a '99-2004 SN95 V6 Mustang 4-wheel disc brake master cylinder I installed, as well as the associated fabrication of the brake plumbing.
2.3L Fox Mustang booster & Lincoln Mk VII 4-wheel disc aluminum master cylinder in a '65 Mustang.
Checking out a 1995 Ford Explorer 4-wheel disc MC, 2.3L Fox booster in a '65 Mustang.
Checking out a smaller diameter, but thicker, 5.0L Fox Mustang booster with Explorer MC in a '65 Mustang.
...decided to install a '96 Ford Windstar 4-wheel disc MC on the 2.3L Fox booster in the '65 Mustang.
...fabricating up some brake lines...
1.
2.
...to install a manual-line lock...because this Mustang didn't have any parking brake cables
Checking out an Explorer MC in my '68 Mustang.
1.
2.
Checking out a 1996 Mustang GT hydroboost setup in my '68 Mustang.
1.
2.
Brake system I plumbed up in a 1956 Chevy Bel Air.
My friend's '65 F100 he brought to me to convert the single pot (suicide) brake MC to a dual reservoir MC, after he installed discs on the front of the truck.
1.
2.
1967 Mustang that was brought to me by a local guy. Among fixing/replacing a lot of stuff on the Mustang, I changed out the 4-lug drums for 5-lug Granada discs on the front and I swapped out the anemic Ford 7-1/4" rear end for a 5-lug Ford 8-inch drum brake rear from a '69 Mustang.
Before:
1.
2.
3.
...after MUCH work:
4.
5.
6.
7.
8.
9.
10.
As I said, I don't know everything there is to know about about Ford brakes, but on the other side of that, I do have a vast amount of knowledge and hands-on experience with them.
