Good afternoon HayHauler and 70_F100, thanks for the excellent replies!
HayHauler wrote:thats a very nice setup you've got there!! snazzy!
Thanks very much! I like the setup and it definitely looks nice, yet it has taken a fair amount of fiddling around to get it all to fit in an ideal way (and perhaps it still isn't an ideal fit). Also, since going this route I've heard from many sources that it's really not a necessary upgrade, especially for my simple, single belt setup.
During my visits to FE Specialties, I've noted that even very high performance, 427-powered vehicles tend to retain the stock V-belt configuration.
70_F100 wrote:Robroy, the second photo really gives a good representation of the belt alignment.
I think it might indeed!
70_F100 wrote:Ii appears that, at the top of the crank pulley and the bottom of the water pump pulley, the belt makes a slight bend.
You can see what I'm talking about in the attached edited photo.
Thanks for taking the time to illustrate what you're seeing in the photo!
I see it too, and I suspect that the crankshaft pulley
is set back a little.
70_F100 wrote:It may be an optical illusion, but I think the crank pulley is offset to the rear slightly.
I'll go out there and eyeball it more closely! The potential for optical illusions is high here. When I'm looking at it in person, slight head movements cause marked changes in the signals being sent from my eyes to my brain.
Yet even when I attempted to measure this (in my crude way, with a tape measure), I did see that the crankshaft pulley seemed to be recessed perhaps 1/32".
70_F100 wrote:I truly believe the spacer Tom gave you is correct for your setup.
I know what you mean--I have that suspicion too.
70_F100 wrote:I know it's a lot to ask, but is there a chance you could change the spacer and take a similar shot with the other spacer installed?
That's probably a good idea! I'll go out there and eyeball it again, and try to make another measurement also. If the crankshaft pulley does seem recessed more than 1/32" or so I may try Tom's spacer as advised!
I'd normally try this more whimsically, but I installed the crankshaft pulley using medium-strength "blue" thread-lock, and my custom-made spacer is very difficult to remove from the pilot. I might need to apply some heat to it to get it to loosen up on there, which is a trick I haven't tried before.
The thread-lock isn't hard at all to snap apart; it's just a hassle to clean the crusty thread-lock out of the threads before putting it back together.
All that said, here's my chief reason for using my custom-made spacer instead of Tom's. With the custom-made spacer, the March crankshaft pulley slides on to the pilot and seems to leave about 1/64" of pilot sticking out when it's fully seated. Since Tom's spacer would be an increase in thickness of about 1/16", I'd be left with
negative 3/64" of pilot remaining, which would mean less than full engagement of the crankshaft pulley.
So this leads to the question, "Which is more important, full engagement of the crankshaft pulley, or improved alignment?"
Two natural inputs to that question come to mind: how much pulley engagement would be remaining if 3/64" were subtracted from 100% engagement, and exactly how recessed is the crankshaft pulley now? It's easy to measure the first input, while the second's not so easy.
70_F100, thanks for your wonderful advice and for provoking me to look at this more closely! What are your thoughts on the above?
