Water jacket drain plug question
OldRedFord
Post by OldRedFord »
On my 460 block, on each side of the blockthere is a water jacket drain plug. Already repaired one, but the other...
I drilled it out fine, but it seems that the passage behind is blocked off from the water jacket?
I tried blowing compressed ai in through the hole, the air just shot right back out.
I tried looking down the water jacket from the deck surface, I can not see wjere i drilled the plug out.
I tried to shine a bright light in from the hole, can not see any light getting through.
What gives?
No the same block, but the plug at the back is in the same spot.
I did ask on the one 460 sie but did not really get a answer.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Water jacket drain plug question
Probably years of crud build-up. Sludge, scale, rust, etc.
That stuff can be really stubborn, and it's tough to get out. Compressed air won't do it.
Try digging into it with a screwdriver and see if you can loosen it up.
JMcTurnan
Post by JMcTurnan »
Soaking some gasoline in there? Maybe degreaser? Let it sit overnight, then try a screw driver.
eggman918
Post by eggman918 »
If it is rust and junk try a small amount of swimming pool acid in hole it will eat the crap but not the good/clean cast iron :2cents:
Gloves and eye protection mandatory ,use acid let it work a bit then flush with water brake it up with a probe/screwdriver might take a couple of times
Good luck
oldschoolrods
Post by oldschoolrods »
my 360's were plugged up solid, took lots of digging out and a trip through the jet spray washer to get it all out. one thing i'm planning on doing is replacing the pipe plugs with radiator drain cocks so the antifreeze can be drained out of the block easier when it gets changed.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
eggman918
Post by eggman918 »
:yt:
drains help to stop that issue in the future if you use them, same principle as the one on a water heater
the junk cant build up as easily :thup:
OldRedFord
eggman918 wrote:If it is rust and junk try a small amount of swimming pool acid in hole it will eat the crap but not the good/clean cast iron :2cents:
Good luck
Can you get swimming pool acid at a local hardware store or Lowes?
Tim
eggman918
Post by eggman918 »
Yes Lowes or a super market it comes in 1 gallon plastic jugs,It is not expencive
BobbyFord
Post by BobbyFord »
I checked my 460 block and found the passage blocked, too. It was just rusty scale. After poking thru, I installed one of these:
JMcTurnan
Post by JMcTurnan »
Mine being a 351w boat motor was a bit scaily at the threads. But it was clear and let fluid out freely when I opened it.
