4bbl CAR intake.Darren wrote:My intake is a 4v cast iron job. I don't remember the number, but there was a D, a 5, and a T. 1975 truck?
dual carbs?
- Redcap
Re: dual carbs?
Re: dual carbs?
A marine engineer in Arizona?!
I guess I should have said ' a marine engineer currently endeavoring for an AAS Degree at a sub-standard community college program in Arizona'
1968 F100 -360, 2BBL, C6, 3.25, ugly? yeah, she's ugly.
1997 Expedition -4.6L, 4WD, 14MPG, gutless? yeah, she's gutless.
2001 Kawasaki ZRX1200R, fast? yeah, she's fast.
- OldRedFord
Re: dual carbs?
ArizonaDan wrote:Understand the engineering behind carburetor selection:
The number of barrels is by itself an irrelevant measure. The useful factor is CFM; 'cubic feet per minute' of air flow into the engine.
Whether you achieve, for example, 600 cfm through 2 or 4 barrels, the engine depends on the 600 cfm and NOT the number of barrels the air flowed through in getting into the combustion chambers.
One barrel, two barrel, tri-power, six-pack, four barrel, dual quad, throttle body, TPI, whatever, the engine requires a quantity of air and couldn't care less how many barrels the air has to flow through to do its job.
That being said, it is a fact that more barrels typically enable greater quantities of air to flow and that is why you see multi-barrel carburetors or multi-carburetors being utilized on larger displacement engines.
I am a marine engineer by trade and appreciate the verifiably proven science behind the numbers of internal combustion engine operation.
Why do I like these old Fords? The simplicity baby, the simplicity.
Interesting. The SBF's, SBC's I have seen all had four barrel carbs. The one FE I ever remember seeing in person (I have probably seen more in the past but didnt know what it was other then a Ford) had a four barrel carb. The 302 in my friends F100 has a two barrel carb.
In my mind a two barrel carb just seems small. Tho most of my engine experience centers around racing.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: dual carbs?
My 67 f250 had a 4 bbl on the 352. I got that truck in 76. It had a cast iron manifold.
Re: dual carbs?
I could have sworn my friends 69 F250 camper special had a stock 4bbl on it. But i could be wrong.
Re: dual carbs?
I also thought 4 bbl's were available in 69, but after a little web research it seems that they weren't put on
trucks until 1975-76 390's.
- AlleyCat
Re: dual carbs?
Yup. 75 truck intake. I have one on the 390 in my 67 and a spare one stashed.Darren wrote:My intake is a 4v cast iron job. I don't remember the number, but there was a D, a 5, and a T. 1975 truck?
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
