1972 Ford F100 Project.
- DuckRyder
Re: 1972 Ford F100 Project.
Looking good!
Painted the rear axle black.
Have been busy installing a back up water line to the house the last few days, but, I found time to pull the engine out of the truck today. Next will be to wire wheel and paint the front rails, pull the I-beam, see if the king pins are ok, and wire wheel and paint also. Also ordered Energy Suspension axle and radius arm bushings for the I-beam. If you think I have overlooked something, let me know.
Tomorrow I will start removing the I-beam. The King Pins have about 1/16" of play. I think they are fine, but I have never worked with king pins before. What do you think, should I leave them alone?
- popeyes71
Wow, your making some good progress! She's going to look great when your done! As for the king pins, I don't have much experience with them either but I would say replace them. It's easier to do it now while the truck is apart, rather than later. I'm sure someone else here will have a little more to add. Keep up the great work!
-Popeye-
1971 F-250 4x4 Highboy
- hfdco4
I would do the King Pins as well. You might want to look into disc brakes for the front too.
FE390PC
FE390PC
I have the disc brakes from a 1978 F150 donor truck, the problem is the 1972 is a manual shift, three on the tree. To much hassle to shorten the 1972 steering column.hfdco4 wrote:I would do the King Pins as well. You might want to look into disc brakes for the front too.
- hfdco4
Convert it to a floor shift. In my opinion, brakes and steering are the two places to over build your project!
FE390PC
FE390PC
Pulled the king pins, one slid out easy, the other one took an hour. They must of been changed before, plastic bushings. I then pulled the I-beam out.
Today I wire wheeled the front frame and gave it coat of acid.
Front frame with primer.
- DuckRyder
Looking good!
Wired wheeled and brushed acid on the drivers side I-beam.
Painted front frame semi-gloss black.
- hfdco4
Nice progress!
FE390PC
FE390PC
Thankshfdco4 wrote:Nice progress!
