DuckRyder wrote:It looks infinitely better inside than out.
Is that a steel shim head gasket I see laying in the drive way? Does it have "FORD" on it?
Yeah i was surprised by how nice it is inside. Those are steel shim head gaskets, however i can't find FORD anywhere on them but maybe i missed it.
BobbyFord wrote:Dorman # for the 1 49/64" brass freeze plugs should be 565037
, I think
fordman wrote:i had that number on a reciept some place. i dont know where it is to confirm if thats it or not.
I pulled one of mine and took it with me when i got the spark plugs and oil pan gasket, but forgot to take it in and get new freeze plugs! So we will know tomorrow.
BobbyFord wrote:Hey, is that a block heater freeze plug on the right side front? Is the oil pump body aluminum or steel?
Is that what that plug is??? I saw it and couldn't figure out what the heck it is. I guess it will be thrown away though when i put in the new freeze plugs. Speaking of which, how do i put in the new freeze plugs?
70_F100 wrote:The pistons look very wet to me.
I know you want to put this thing together in a hurry, but if it was me, since you have it down this far (and don't know the full condition of the engine) I would go ahead and freshen it up, including tanking the block and replacing the cam bearings.
I would, at minimum, pull the main and rod caps and check the bearings.
For just a few extra bucks, you could have a freshly-rebuilt engine that you would easily sell when the time comes.
Just my
The pistons were actually not "wet" like at all. But as i look at the pictures they totally look wet. It's the way the flash bounced off all the particles i think. The material on the pistons was a dry chaulky substance.
This is as far as the engine will be torn down, I simply don't have the money (and time is starting to be an issue) to go any further. I literally have $200 now, and i didn't plan on buying any of the stuff i just bought. That $200 won't last long with gas for the '71 either
