rattle caning, and smoothing out the paint
re: rattle caning, and smoothing out the paint
How many cans, would you say, did it take?
- jzjames
Like I said, I did my whole truck. I did alot of careful prep work, sanding ALL the cracks and crevices with 220 grit paper. I cleaned and sanded the door jamb areas to the point of the door gaskets, the underside of the front driprail, etc. I used a little primer on bare metal parts, and then sanded that lightly. I painted one panel area at a time, taping it off with masking tape and newsprint.
The cab took about 10 cans - $35.00. Probably about another 10 cans for the box. jz
Re: re: rattle caning, and smoothing out the paint
For sure 2 is not enough for the just the hood, because I ran out.greenbank wrote:How many cans, would you say, did it take?
- Joe Kriston
Jz,...it looks good in the pics....Can you,like,buff out runs and rough spots?....How is the color match from can to can?....Also,how do you keep the rattle can from dripping paint on your nice work when you're painting the hood?
- jzjames
Color match is no problem. The type of paint I used, "engine enamel" has some kind of ceramic compound in it and is somewhat slow drying. It is high gloss though. If you were to get a stray run, it can be sanded out after a few weeks of drying. My spraying is OK which limits the runs, but I did get a few. The colors of the engine enamels is limited though. There is a type called "Truck and Van Paint" too, which I have used and thought was OK. It is more like laquer though and is quick drying, easily sandable but not as durable. Another paint in the spraycan I liked is called VHT brand.
I did not cover everything with primer first, and where I shot a little primer on bare metal spots, I sanded it alot almost to the point of taking most of it off. The main thing I say about trying to use spraycans for panels is to prep thoroughly, by sanding down to 220 grit. That is 90% of the time involved. Wipe it all down with a towel or something and on the first coat, just lightly "mist" the whole panel - and let it dry. Then start with the light coats. If you try to cover too fast (thick) you'll get runs. I used 2 to 3 coats of paint after the initial mist coat. And let it tack up a little between coats. Always keep the can moving when spraying. jz
I wonder if taking the hood off and standing it upright would help any, that way the only horizontal spraying you would have, would be top of cab. I know more work and would need a buddy to help remove and replace hood when finished. Anyway just a thought.
1968 Ford Pickup
1998 Ford F-150 extended Cab
2000 Ford Explorer
http://www.fordification.com/galleries/ ... ?pos=-1469
2000 Ford Explorer
It been said but I will be doing the same thing, I would actually love to have somebody professionally do it but I definitely do not have the cash flow for that, and I don't have my own sprayer so I am pretty much stuck with rattle can. I think I can pull off a decent look.
That is a good idea.frankc67 wrote:I wonder if taking the hood off and standing it upright would help any, that way the only horizontal spraying you would have, would be top of cab. I know more work and would need a buddy to help remove and replace hood when finished. Anyway just a thought.
why don't you just buy a paint gun and get some auto paint and spray it with a good gun
I think you problem lies in that the paint is too thick, that paint thinner ratio is what gives you a nice paint job. You said you wanted candy apple red, well you could get a candy red paint and add some metal flake to it and make it sparkle, I've seen someone paint a car that had sparkle in it from the can and they've had nothing but trouble. And a good gun can be had for a decent price. A friend of mine that is restoing a truck got two gravity fed guns(large and small) plus all the different tips it came with for $100, and you get to keep it and use it again at another time.
