1970 F250 4X4 Rebuild / Updating
- hfdco4
Re: 1970 F250 4X4 Rebuild / Updating
Another cold weekend is over and no work on the truck. It is supposed to be over 32 all this week, but drop down at night. The plan is to take the caliper mounting bracket to work so I can clean and paint it during my lunch breaks. Then I have to do the axle u-joint.
FE390PC
FE390PC
- cdnwillyg
The cold weather can put a damper on most builds, I for one love to work with the garage door open or even on the driveway in the sun but not so much when it's cold. I am able to work inside in heat but just not the same when all closed in. And not feeling good will not help either, get well!
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- Manny
You still need these two i got here just one or what you think. Understand the frozen to death working.hfdco4 wrote:Another cold weekend is over and no work on the truck. It is supposed to be over 32 all this week, but drop down at night. The plan is to take the caliper mounting bracket to work so I can clean and paint it during my lunch breaks. Then I have to do the axle u-joint.
- hfdco4
I am interested in both. What size rotors are on that axle? If they are the same size as the 44 then i need them!
FE390PC
FE390PC
- hfdco4
Got the Caliper Bracket blasted and painted so still on schedule. Hope to actually get more accomplished this weekend finally!!!!!!!
FE390PC
FE390PC
- Manny
hfdco4 wrote:I am interested in both. What size rotors are on that axle? If they are the same size as the 44 then i need them!
Cleaning them up for you they will make it to ya.
- hfdco4
Awesome!
FE390PC
FE390PC
- hfdco4
OK for anyone still tuned in. Got out to the garage today and got some tasks done. I installed the new u-joint in the short side axle and put the two caliper brackets on. I got the tie rod and cover cleaned and painted.
Tomorrow being a holiday means I can get the hubs done pack the wheel bearings and get the axle attached to the frame finally!
FE390PC
FE390PC
- Manny
You need the spring and cup, and these caliper brakets? Thought you had one hashed but glad to see your moving and making progress. I can ship out tomorrow if i need to.
- hfdco4
Don't need the spring and cup as I figured out they are not needed for the Hubs I am using. I do need the two brackets as the ones I have have seen better days. I just need to get the frame rolling along so it can move out of the garage and the cab can move back in!Manny wrote:You need the spring and cup, and these caliper brakets? Thought you had one hashed but glad to see your moving and making progress. I can ship out tomorrow if i need to.
FE390PC
FE390PC
- Manny
hfdco4 wrote:Don't need the spring and cup as I figured out they are not needed for the Hubs I am using. I do need the two brackets as the ones I have have seen better days. I just need to get the frame rolling along so it can move out of the garage and the cab can move back in!Manny wrote:You need the spring and cup, and these caliper brakets? Thought you had one hashed but glad to see your moving and making progress. I can ship out tomorrow if i need to.
Roger wilco. I will try and blast those brakets tomorrow. They are rusty but they have not been welded or anything. Get them cleaned up and you should be good.
- hfdco4
Manny wrote:hfdco4 wrote:Don't need the spring and cup as I figured out they are not needed for the Hubs I am using. I do need the two brackets as the ones I have have seen better days. I just need to get the frame rolling along so it can move out of the garage and the cab can move back in!Manny wrote:You need the spring and cup, and these caliper brakets? Thought you had one hashed but glad to see your moving and making progress. I can ship out tomorrow if i need to.
AWESOME!
FE390PC
FE390PC
- hfdco4
I got out to the garage this morning for about four hours. I got a lot done and here are the pics.
I still have one plate to find and get the Drivers Side u-bolts installed.
I picked up a 2 gallon jug of gear oil at Tractor Supply today to fill both axles.
Then it is being rolled outside and covered so the Cab can come inside and get started!
FE390PC
FE390PC
- hfdco4
Still looking for my plate on the drivers side spring. Here is a pic of it.
I know it is in the disaster area of my garage. I cleaned and painted it so it is there!
FE390PC
FE390PC
- popeyes71
she is a roller! That spring plate will show up eventually.
-Popeye-
1971 F-250 4x4 Highboy
