steering column seats sideways
- fordelio
Hi, my 69 F100 4x2 shows its steering column seated sideways so column is not centered refering to the metal cover in the dashboard. I already tried to center it by removing the steering support and external dash cover bolts without any improvement. Please anybody can tell me how to solve this problem? regards, fordelio.
- jeepgod
Re: steering column seats sideways
Mine sits sideways a little to. I have a manual steering column with a power steering.
2003 VW Jetta 1.8 turbo
1996 Lexus LX450
1969 Ford F-100 2wd 302
1996 Lexus LX450
well the steering column isnt centered in these trucks. they do have an angle to them. if it is not a factory look. then maybe the cab mounts are rusted out and the cab has moved or to one side.
Mine is a little to the left, me thinks this is normal on these rigs.
Yep - they all do. If you look at the steering box, it's mounted somewhat at an angle and that angle transfers all the way to the steering wheel. You may also note that the motor is not centered in the truck either!!!
- BobbyFord
It's because the frame rail that the box mounts to is inboard of where it would need to be to center the column.
- fordelio
Hy everybody:
Thanks a lot for your helpful comments about this issue. So as I understand we must learn to live with it; little more to do. Glad to be in contact with this great community ¡¡¡
Been driving my truck for 37 some odd years and never noticed that. Dang, I'll see it every time I get in there now. Thanks
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Clint - we don't mean to change the way you feel about your ole' girl. Please note that Ford did not do this with trucks shipped to North Carolina. Your wheel is straight as an arrow - you lucky dog you!
- FreakysFords
- papabug71
Also, as fordman mentioned, if your cab mounts are rotted/fatigued it makes this condition more noticable. The cab on my '72 parts truck was basically resting on the steering column & it had cocked over a good way from where it should have been. We literally had to jack the drivers side of the cab up in order to pull the steering column.
Matt
1971 F-100 Sport Custom - My grandpaws truck
Been in the family since 10/3/'71 (Brand spankin' new)
Mine since 5/7/'94
302 / 3 speed / 3:25's
--Currently undergoing full frame off resto/mod--
