The official 6bt conversion thread
- xxxtina63
re: The official 4bt conversion thread
Oh, almost forgot. It's mandatory for all restaurants to switch to low linolenic oils to comply with the new trans fat regulations. Don't know if they are really more healthy for you, but they require much less heating than what's been around in the past. And while it's still thicker than water at room temp, it doesn't thicken into a block when it gets cold. Should require a lot less heating to be useable. However, I don't know if the new soybean based oil is better or worse for mileage.
My FORDification Photo Album
- averagef250
- j41385
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
Dustin how much will you charge me for a set of motor mounts for the 4bt. What does a rebuild cost on the 4bt? Also out of all the transmissions we have discussed which one do you think is the best. So to hook it up it only requires one wire from the starter solenoid to the starter? Is that correct. What about the sensors. DO I need to get then fro a ford dealer if I go with the Chebby one I found?? Thanks for all the info!!
- averagef250
The last two for now.
- j41385
So why does the 6bt not have the fuel timing advance for cold starts, and have the heated intake grid instead?
- averagef250
I don't really know. My best guess is that because the 4BT was a retrofit motor in many cases cummins didn't want to complicate the installations with the intake grid. Just a guess, I really don't know, just can't say I've ever seen a 4BT with the heated grid and every 6BT I see has them.
- xxxtina63
That '94 is going to be pretty sweet when done
. Kind of makes me wish I'd picked up a '92 4x4 a local guy had for sale for $800 with a clapped out 4.9/5spd.
- averagef250
The '94 is pretty nice. It actually started life as a super clean '94 F-150 2wd. I put the body on an '87 F-250 4x4 frame and added the 4" springs and BFG's. The guy really liked his truck, just wanted the exact same thing, but big and burly, now he's pretty much there. I'd say he'll have around $10K into it all said and done including what he bought the truck for. That's about what you'd pay for a decent powerstroke of the same vintage. He likes the idea of the cummins. He spends a lot of time in BFE northern Alaska and wants the rock solid reliable simplicity of the 4BT. After the motor's done he wants a 60 up front.
What ford motor mounts will work? Or which ones should I look for on ebay? Also what do I need to modify on them when they come? Thanks so much for letting me pick your brain.
- averagef250
The brackets that attach to the engine are used in 80's and 90's 4BT ford installs. The rubber mounts themselves are 80 something to '91 dodge 5.9 cummins mounts. This stuff all bolts on and needs zero modification and bolts in with zero mods to the truck into any 1980 and newer ford chassis that was available with the 300 six.
What must be modified is the frame stands on 1979 and older ford trucks to match the newer style motor mounts. The 4x4 frame stands must be cut down about 2.5"s and the angle is different. The ones I have made you cannot tell they are not factory. Also, if your truck is a V8 truck you must move the frame stands up to the 300 six set of frame holes and drill 4 new holes, two in each side, to bolt them in. Drilling the holes is very easy.
- 460 crew
What happens with front crossmember clearance? I know the 6bt you have to hack it up and drop it a bit. Does this engine sit behind or above to clear, or is it just shorter?
- averagef250
You don't need to touch the crossmember with the 4BT. When installing a 6BT into a '79 or earlier ford 4x4 you have to drop the entire engine and tranny down atleast an inch to clear the radiator and firewall by an RCH. The transmission also gets moved back a couple inches to put the back of the 6BT right against the firewall. The 24V is even worse, actually will not fit without firewall cutting because of the way the rear of the head is cast and how the one piece valve cover has to come straight up to come off. The 4BT bolts in and sits like it came there. Well, it does sit back in the frame a bit more than it would seam it should, but sure makes getting in the engine bay to work on anything nice.
- 460 crew
Right on! I have a buddy that keeps trying to talk me into just dropping a 6bt in there and I might regret it if I don't due to lack of power. I figure I'd have the best of 2 worlds with the 4bt nice power and fuel mi along with simplicity. Sure would be nice to have all that room after fighting the 460 all the time.
My dads 24v usually pulls a consistant 17mpg on average, that just doesn't seem that appealing. If the little brother of the 6bt does what your saying why would I even concider a more expensive more time consuming conversion?
- averagef250
