Battery wasn't holding a charge, so I took the alternator in to the local parts store for a check-up. It was a Delco-Remy that was in the F100/LTD. You see, the Goose originally had a 240/3 speed manual combo, which a previous owner swapped out for a 400/c6 combo from a 71-72 full-size car. It failed the test and I got a replacement alternator with all the plugs and posts matching the original, in the original places:
You see it has a plug in there. Problem is, there is no plug on the motor. Also, I have a bit of a shortage of contacts for this year truck. These two wires were all that was connected:
Those two wires run to the voltage regulator....
...and the starter relay:
So the question is, what did Bubba do to this truck and what do I need to do to hook this up properly?
Thanks in advance and
