lowering 68 swb
kool patina
lowering 68 swb
Post by kool patina »
Been wanting to lower my 68 swb for some time. I recently have read that DJM Dream Beams are JUNK! Was told to look for 93-93 Lightning beams, that they were factory lowered beams and I was told today that the beams are the same on any 93-95 1/2 ton , just the Lightning had used lowering springs and shocks. Could I install factory 93-95 stock beams and torsion bars, with disc brakes on my 68, and look for a good after market lowering spring and shock, and I know I will have to probably have the stock beams hydraulically bent to correct camber settings. Who make a good lowering spring, and what is the drop on it? I thought if I could not install 93-95 factory beams with disc brakes on my 68, I would re-bush king pins and locate after market lowering springs and shocks , bend my stock beams to correct camber...would like to get rid of the king pins and drum brakes. Anyone ever do this? Thanks!
HIO Silver
Re: lowering 68 swb
Post by HIO Silver »
Don't believe everything you read. The internet is notorious for misinformation. But it sounds like you did alot of research so go for it.
Many a Fordification members have used DJMs with little to no issues. What is "JUNK" refer to? It was probably an idiot behind the wrench.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
DCrusher
Location: Hurst,Texas halfway between Dallas/Fort Worth
Re: lowering 68 swb
Post by DCrusher »
I have DJMs with 76 disc under mine very happy with them no problems.
http://www.hottottyscreations.com
55 F-100
57 Oval VW
68 F-100 3" Dropped Axles & Rear Hanger Flip
88 Dodge Ramcharger
97 F-150 Extended Cab 4" 6" Slammed
moon.dog62
Re: lowering 68 swb
Post by moon.dog62 »
Try airbagit they also make lowered beams, and they are not tube welded together as you say about djm beams but fabricated I beams.
