Rear - So far I’ve bought:
Hardware kit including the adjuster hardware
Wheel Cylinders
Drums
Shoes
Monroe shocks
Brake Hose
Energy Suspension 4.2139G Bushing kit (I have the Flex-o-matic shackles) any tips on installing these?
What I need:
Fabricate brake lines
Shackle Bolts – can’t seem to find them anywhere, and I struck out at the hardware store matching up to the old ones. Any ideas?
Parking Brake Cables – I can’t find the RH one, apparently no one makes it. Both cables on my ’69 donor look good but I haven’t taken its drums off yet. Any concern with using these if they’re in decent shape?
Front – So far I’ve got:
Complete suspension from ’73 donor including coils
New LH and RH Brake hoses for a ‘73
New LH and RH Rotors for a ‘73
LH and RH Brake hose brackets from ’73 donor
New Brake Pad set
New Monroe shocks
Brake proportioning valve with bracket from ’73 donor
Brake booster from ’69 donor with power drums with firewall brackets
Energy Suspension Axle pivot bushing set
Energy Suspension Swing arm bushing set
What I need:
Calipers (plan on O’Reillys)
Wheels bearings (plan on O’Reillys)
Master cylinder – I assume I need a master for a ’73 with power disc/drum? Will it mate to the ’69 booster?
I’m told I need the steering box and pitman arm off the donor ’73 to dodge any potential issues with that, that’s a direct bolt-in replacement, right?
And regarding the proportioning valve, where to mount it? It doesn’t look like it will fit where it was on the ’73. I’ve seen some pictures that look like the valve mounted to the top of the steering box (without the frame bracket of course) Is this what’s recommended, or was this a factory position on some of the later dentsides?
I know I have a ton of questions, but if you guys can start helping me knocking them out, I’d really appreciate the help!
