Lately I've been reading, "How to Rebuilt BIG-BLOCK FORD ENGINES," by Steve Christ. What a wonderful book for anybody interested in FEs!
Before reading this book, I was aware only of standard 352, 360, and 390 FE engines. I was vaguely aware of 427 and 428's also, although I didn't know about their significant features that made them different from the standard FEs.
Some of the exotic features that I've learned about include:
- Cross bolted mains, with the bolt heads sticking out on the sides of the block skirt.
- Freeze plugs that screw in instead of pressing in.
- "Side oiler" engines with special oil ducts going along the side of the cylinders.
- Engines with thicker walls around the cylinders.
- Specially built engines with forged steel crankshafts, borrowed from FT blocks.
- Engine blocks made with high nickel content, or made using special methods to increase the strength of the cast iron.
- Extra support for the main bearing saddles, cast in to the block.
- An oil pressure relief system with a special valve on the rear block face.
I've noticed that lots of contemporary crate FEs are based on regular 390 blocks and heads, including the one I recently bought. And they advertise performance in the range of 400 horsepower, or even 500 when aluminum Edelbrock heads are used. From what I've read, depending on the head modifications (or aluminum heads), these are realistic specifications.
So if these standard FE blocks and heads can produce this kind of power, what's the big attraction towards these exotic FE blocks and heads (especially the blocks)? Why do people pay so much more for 390HP, 427, and 428 blocks?
Did Ford find it necessary to enhance the FE because hot rod methods used in the 1960's and 1970's weren't able to get enough power out of the standard FE blocks? And has that changed with modern methods?
Or are all these modern hot rod engines based on standard FE blocks not as strong as they could be?
Thanks very much for the truly fantastic advice!
