67 F-250 2wd frame up restormod 6-9(Warning!)Large pics!
FordTruck
Re: 67 F-250 2wd frame up restoration
Post by FordTruck »
Dadgum that truck is CLEAN, Good luck on your project,I olny did a cab swap and it wore me out. :thup:
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
stangconv
Post by stangconv »
wow.. this is exactly what I am going to do...
dcbullet
Post by dcbullet »
Looks like a pretty good base to start with. I look forward to seeing your progress.
fireguywtc
Post by fireguywtc »
Got the truck down to bare frame. Got everything off except all the suspension and brake lines.
Cab coming off. It needs the most work, but I was glad to find out when I took all the glass out all the frame under the gaskets still look as good as from the factory!
The bare frame.
The sticker thats been on the truck since I have owned it. (it's for the anti logger hippies). BTW if anyone can get me some more of those stickers please contact me :pray: :drool:
Bill
fireguywtc
Got the frame painted today with the help of my wife. Used por 15 and it went on nice. A lot of sweat equity went into the prep of the frame so I am glad that is done! Next goal is to get all the suspension painted and put back on so I can have a rolling chassis again. When it is all prepared I will move it outside and cover it for storage to free up room to work on the body in the garage.
Bill
stangconv
Post by stangconv »
Damn looking good!!! :thup:
69twotone
Post by 69twotone »
Wow, You are moving along quickly. Did you use the cherry picker to lift your cab off?
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
fireguywtc
69twotone wrote:Wow, You are moving along quickly. Did you use the cherry picker to lift your cab off?
Yup that is how I got the cab off with a little muscle help. For the time being that is all it is being used for is to move the cab.
Bill
dcbullet
Post by dcbullet »
Man, all these people with beautiful frames!
:thup:
PhilthyF100
Post by PhilthyF100 »
at the speed you're going you'll have it done in no time :thup:
looking very good. Though the truck looked damned nice to start with :D
1969 F350 wrecker
1975 F100
1973 Falcon hardtop
fireguywtc
Re: 67 F-250 2wd frame up restoration updated!
Just an update. Have not been getting as much work done as I would like since the holidays keep me pretty busy with other stuff going on but I do work on it when I can. I had to abandon working on the chassis for a while. Waiting on machine work and getting other hard to get parts together to finish assembly. I started working on the cab in the mean time. Started putting in the new floor pans and cut out the kick panels since they where badly rusted. The floor pans are more work then I had hoped but just setting them in there and seeing how nice they look makes it worth while. Next I will work on getting the new cab corners put on and maybe the new cab mounts as soon as I figure out how to get those on correctly :P Not pictured I got the floor plans temp tac welded in, this weekend I will try to do all the finish work on getting them installed.
cab floors cut out and everything cleaned up
mice nest I found in P/S kick panel. It was by far more rusted then the D/S which had no nest. I did cut the D/S out also since the insides are both rusted a lot!
holy cab corner :lol:
Bill
fireguywtc
Re: 67 F-250 2wd frame up restoration *updated!*
Got the floor pans in finally. I do have a little touching up to do, I ran out of wire on the welder. Plus doing a little touch up grinding. Please don't make fun of my amature welding, what a pain it was to spot weld all the way around those pans!
Before and after pics
Bill
fomocoguy
Post by fomocoguy »
Lookin good! I sure wish I had the room to to the same to my truck. It may end up in pieces in the back yard come spring... :lol:
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
fireguywtc
I don't have that much room, just a 2 car attatched garage. Just the cab and chassis is in the garage at the momement. The bed is in the back yard with the entire front end inside of it. :roll:
It's my belief that the size of a shop is like the size of a pay check. You always want a little bit more. I definetely want more!
Bill
MadMaxetc
Post by MadMaxetc »
That cab is going to be a lot of work...but very rewarding!
Looking good!
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
