Hello,
Recently purchased a 1969 F100, 302, 3 on the tree, 2x4. hard to tell if it is a Ranger. It has the Ranger grill, long wheelbase, the box has been swapped. It currently has a flare side. not sure if the original box was style or flare. Other than emblems. is there other ways to tell what the model of the truck is? I believe the code i see is 83. Also Im in need of some resources for parts.
1000 Islands NY, new to the Ford way of thinking
- 67mann
Re: 1000 Islands NY, new to the Ford way of thinking
from NY and see if this help's some of your Q,s http://www.fordification.com/tech/technical-index.htm
don't think that 302 would have been original
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
from Massachusetts.
Welcome from Michigan. The Ranger models had all the trim pieces inside and out.
Kyle
Kyle
