390 FE - What Oil to use???
tedbull
Post by tedbull »
I have heard that the 390 motor in my old ford needs a special oil or at least a zinc additive. Is that correct? Also what weight of oil do you guys recomend? I have been using castrol gtx 10-40 for a few years, and then 20-50 for the last couple years. The motor developed a bad oil leak and I wanted the thicker oil in there. I have fixed the oil leak (oil filter adapter gasket) and am overdue for an oil change. The motor doesnt have more than 60,000 miles on it, the truck is a 69 f-250 4x4. Not sure if it matters but the internals are stock, but motor has headers, full dual exhaust, holly intake, holly 670cfm carb. The weather here near seattle is not extremely hot or cold. What oil types and viscocity would be the best for my old motor? Or does it realy matter? Thanks.
Ted.
hotrodfeguy
Re: 390 FE - What Oil to use???
Post by hotrodfeguy »
The thing I go by and you put the info in your post TY is temps you operate in. I like a 10-40 when above freezing, and 10-30 under. Now the Zinc ZZDP is for the Lifters/CAM the pressures there are high years ago with good quality lifters made in the USA and not offshore this was not an issue. But such is life. Thus if you have changed out your camlifters from stock its wise to put that in there.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
tedbull
Post by tedbull »
hotrodfeguy wrote:The thing I go by and you put the info in your post TY is temps you operate in. I like a 10-40 when above freezing, and 10-30 under. Now the Zinc ZZDP is for the Lifters/CAM the pressures there are high years ago with good quality lifters made in the USA and not offshore this was not an issue. But such is life. Thus if you have changed out your camlifters from stock its wise to put that in there.
Ok Thanks. I will change to 10W40 like I run in the rest of my vehicles and look for the ZZDP.
F100builder
Post by F100builder »
I could be mistaken or misunderstanding but I don't believe it has anything to do with the cam/lifter material or pressures of years ago as all oil had this additive once upon a time and they were, as far as I know, all flat tappet engines. I would say that all flat tappet motors should use the ZDDP oil or add it to an oil without it. This is absolutely MANDATORY when breaking in a new cam and lifters if it has flat tappet lifters. The ZDDP has slowly been removed from many oils over the years by the EPA as it's considered an unnecessary pollutant. It is not necessary at all in modern roller cam engines because the friction is greatly reduced just by their design (I guess pressure could come into play here but it's the opposite). Moreover, the ZDDP slowly escapes the crankcase via exhaust (pollution) and it kills catalytic converters by clogging them up.
Now, I'm certainly no expert so hopefully someone can correct me if I'm way off but this is what I've understood by what I've heard from several different people. There are oil companies that have us, the classic vehicle owners, in mind so the high-zinc oils can still be found. Typically, the oils that have 'break in' in the name, will have a high zinc content and should be used on a first fire up. There are also non break in oils that still have a sufficient amount of ZDDP that will provide adequate protection to your flat tappet camshafts after break in. Do your research and find out where you can get what you want but you can always mail order what you like if you can't find it in your local area.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
F100builder
Oh, and unless you live part time in the arctic or in Death Valley, I don't feel that there's much of a reason to concern yourself with switching up the weights of the oil. I tend to run a weight that suits the mileage and wear of the engine. An old, high mileage, sloppy engine with bearings on the brink of becoming just a memory might benefit from a 20-50 or 15-40 and/or a high volume pump. In a freshly machined, tight engine with properly verified oil tolerances, a 10-30 or 10-40 is absolutely fine and with the right machine work performed by a competent machinist, an old FE can run 40-60 psi all day long with a standard volume oil pump. I plan on running 10-40 in my 390 all year long here in south western Idaho where temps can range from 0 (occasionally barely negative) in the winter to 110 in July and August.
Patrick
basshound71
Post by basshound71 »
I use Amsoil Z-Rod in my 240. It has the high zinc rating your looking for.
1971 Ford F100
2007 Chevy Avalanche
Clunker
Post by Clunker »
:yt: I looked into the oil thing a while back and came to the same conclusion. I've had great luck with Amsoil in my econobox (better mileage), and I think that their Z-Rod product is the way to go. The rep at the factory recommended 10-30 to me for the old FE engines, but 10-40 is probably fine. For my first oil change, I decided to go with the conventional 10-40 that I already had in the garage along with a zinc additive. The zinc additive was somewhere around $9 if I remember correctly, so I don't see any cost advantage to going conventional + additive over synthetic that includes additive. In another thread, another forum member suggested Shell Rotella, which also has a high level of zinc.
gregamorton
Post by gregamorton »
I have turned into a 15/40 diesel oil man my self in all my ford engines.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
basshound71
I know after using the zrod oil my motor quieted down a ton. Now hopefully it frees up the lifter I have sticking.
1971 Ford F100
sweetlou
Post by sweetlou »
gregamorton wrote:I have turned into a 15/40 diesel oil man my self in all my ford engines.
I use 15/40 Delo or Rotella what ever is cheaper at Wallymart. Always have on all my cars and trucks. :roll:
72BahamaBlue
Post by 72BahamaBlue »
:yt:
15W-40 Shell Rotella for my trucks.
tomohara
Post by tomohara »
Was told today by a friend that my '69 390 was intended for single weight oils (30 wt, 40 wt etc) and suggested I use that. Haven't heard that anywhere else - perhaps hogwash?
1970FordTK
Post by 1970FordTK »
I live in central North Carolina and have used the bulk 30w oil out of the 55 gallon drum for farm use in every motor/engine on the whole place. The cars/trucks and all the farm equipment, all I know is that it works for me. Just remember some of us go back far enough to know what the metal spout with the knife insert is for..........and back then most oils in the can where strait weight.
1972hiboy
Post by 1972hiboy »
Chalk another vote for the 15w-40 delo. when I went through me engine a couple years ago the cam shaft manufacturer even said on the box to use a delo 15w-40 or rotella for break in.
Rich
Dont eat yellow snow.....
radioactivelarry
Post by radioactivelarry »
Clunker wrote::yt: I looked into the oil thing a while back and came to the same conclusion. I've had great luck with Amsoil in my econobox (better mileage), and I think that their Z-Rod product is the way to go. The rep at the factory recommended 10-30 to me for the old FE engines, but 10-40 is probably fine. For my first oil change, I decided to go with the conventional 10-40 that I already had in the garage along with a zinc additive. The zinc additive was somewhere around $9 if I remember correctly, so I don't see any cost advantage to going conventional + additive over synthetic that includes additive. In another thread, another forum member suggested Shell Rotella, which also has a high level of zinc.
basshound71 wrote:I use Amsoil Z-Rod in my 240. It has the high zinc rating your looking for.
You just can't beat Amsoil, it is the best. Check it out here for 10-30 Z-Rod: http://www.amsoil.com/shop/by-product/m ... e=ZRTQT-EA 10-30 works great as a replacement for straight 30 weight in your FE.
10-50 Z-Rod: http://www.amsoil.com/shop/by-product/m ... e=ZRFQT-EA
Regular premium Amsoil also has levels of zinc and you can run that in your engines.
I have been running Amsoil in my vehicles since the late 80's. I have been running it in my 64 T-Bird since then and I have ZERO problems with any oil issues including no leaks. I also run it in my newer vehicle also.
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
:drive:
