1969 F250 Highboy, bearing, kingpin whatever question
- booblinker
I have a 69 F250 Highboy. I found the lower bearing and cup that I can get from my warehouse, and can get the wiper from Jeffs Bronco Graveyard. I am just wondering what is on the top of the knuckle, and where I can get it, or if anyone offers a full kit to replace everything. I have done a ton a searching and can't find much of anything.
- Swegner99
Re: 1969 F250 Highboy, bearing, kingpin whatever question
Im lost, pictures maybe?
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
1999 F150 Ext Cab
I may be wrong but LMC is listing a Dana 44 as the front 4wd axle on a 67-72 F100 and F250 and it appears to use ball joints.
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=112
#14 and #15 in bottom diagram
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=108
- booblinker
Bottom diagrahm is for an F100 onlyjustiz00 wrote:I may be wrong but LMC is listing a Dana 44 as the front 4wd axle on a 67-72 F100 and F250 and it appears to use ball joints.
1969 F250 High Boy 360 4 speed
-3" Body Lift
-36x12.50 tires
-Edelbrock Intake, Mallory Distributor and coil, long tube headers, and true duals with flowmasters
-Who knows what else I haven't figured out
-1993 Ranger 3.slow 4x4 DD
-1971 F100 302 auto
-1985 Tri-z
-ATC70 with a 125 motor
-A few 200s's
-3" Body Lift
-36x12.50 tires
-1971 F100 302 auto
-1985 Tri-z
-A few 200s's
My 67 f100 4x4 had the trunion bearings. Your 69 f250 4x4 should have the same setup top and bottom.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- booblinker
Ok Finally found a good breakdown and see how it all works now.
-3" Body Lift
-36x12.50 tires
-1971 F100 302 auto
-1985 Tri-z
-A few 200s's
-3" Body Lift
-36x12.50 tires
-1971 F100 302 auto
-1985 Tri-z
-A few 200s's
