What are these rubber inserts in disc brake arms?
- robroy
Good evening,
While refinishing my disc brake arms (the chunks of metal that the calipers bolt to), I noticed these rubber inserts in the holes that house the caliper mounting bolts.
What's the deal with these rubber rings/inserts? Do they typically come with new calipers? Or are these part of the disc brake "arm?" And are they important to retain or replace, or may they be discarded without penalty?
Also, what's the proper name of the disc brake part I'm talking about?
Here's the photo:
Thanks very much!
-Robroy
Here's the photo:
Thanks very much!
-Robroy
- olgreen69
Re: What are these rubber inserts in disc brake arms?
im not sure what the name of that part is as it is only 2" of it, but i would say that is some sort of bushing and would most likely invest in a new one.
- Joshpow
They are a caliper bolt bushing I believe. They are what allows the caliper to move as needed. I believe some parts places have replacements, but I am not sure of that.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- robroy
Hey, thanks for the replies!
Okay, I'll try to look for caliper bolt bushings and see what I find. Thank you!
-Robroy
-Robroy
- robroy
Hi! I haven't been able to find much. Does anybody happen to know if this bushings normally come with new calipers?
Thank you!
-Robroy
Thank you!
-Robroy
not with the ones i bought for my 94 f250 they ddint. those were still on my brackets. they were still good. they have the cone shape thing over the head of the bolt on the newer trucks. i would guess they were that way on the older trucks too.
These are available, I have the box and part number for what you are looking for, I will send you the information tomorrow.
Thanks,
Bill
Thanks,
Bill
- flyboy2610
I would be interested in that info as well. I will be rebuilding a couple of calipers in preparation for a brake swap next spring.Billiam68 wrote:These are available, I have the box and part number for what you are looking for, I will send you the information tomorrow.
Thanks,
Bill
Thanks!
Red Green
you'd better be right.
Red Green
- robroy
Hey Bill! Thanks for much for offering this information; I'd be very happy to find a source for these new! Mine are pretty gnarly and beat up.
Thanks again Bill,
-Robroy
Thanks again Bill,
-Robroy
I was not able to find my box with parts but I did find all the information we need on Napaoline.com. Here it is, make sure to use never seaze on the bushings.
Caliper Hardware Kit - Front
Item#: UP 82113
Price: $14.99
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Attributes:
Features & Benefits:Includes The Bushings
Anti-Rattle & Retaining Clips As Required For Safe & Consistent Braking.
Features & Benefits:Insulating Rubber Compounds (Where Applicable) Help Dampen Noise & Vibration.
Features & Benefits:NAPA Disc Brake Hardware Components Are Coated To Resist Corrosion & Prevent Rust.
Features & Benefits - 2:All Parts Are Properly Heat Treated To Provide Maximum Durability.
Features & Benefits - 3:ISO 9001 Certified Manufacturing Facility Ensures High-Qualilty
Premium Product.
Product Features:NAPA Hardware Kit Components Are Designed To Match O.E. Fit
Form & Function.
Click on image to see enlarged view
Item#: UP 82113
Price: $14.99
Attributes:
Premium Product.
Form & Function.
- Joshpow
Cool! i'll most likely need those myself. Glad someone found them.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- flyboy2610
Thanks for posting that!
Red Green
Red Green
- robroy
Good morning! Awesome information, thanks for posting the NAPA part number!
I checked it out and made these observations:
1. Part 82113 does one caliper only; part 82113A does both.
2. Part 82113 is listed for 1972 F250's with chassis serial numbers up to M80001.
3. Part 82116 is listed for 1972 F250's with no serial number restriction.
4. Part 82116 has the description, "Heavy Duty Kit Services 1 Wheel Only."
5. The image of part 82116 indicates that it comes with fewer parts.
Here's 82113A:
Here's 82116A:
So the question for all of us will be whether we should order part 82113 or part 82116.
My F250's chassis serial number is P60524. Since that's beyond M80001 I'm guessing that part 82116 would be right for me.
Of course I could talk to NAPA directly but you can guess what the result would be (chances are that the counter guy would have never even heard of our trucks).
Does anybody have comments on the 82113 versus 82116 question?
Thanks!
-Robroy
Here's 82113A:
Here's 82116A:
Thanks!
-Robroy
- robroy
Upon closer inspection, it appears that the only parts from the bushing kits that are currently installed in my arms are the metal (silver colored) bushings with the rubber inserts in the middle. I don't see anything like those big springs or the other parts there.
Does anybody else recognize all the parts in those kits?
Thanks!
-Robroy
Thanks!
-Robroy
The springs go in between the brake pads on the top and bottom guide bolts inorder to seperate them away from the rotors when not in use.
