Article 2994 - Ignition Lock Inoperative
TSB #146 - August 7, 1970
(All 1970 Car Lines)
Ignition locks located in the steering column may become inoperative due to a broken retaining pin. This condition can be corrected by replacing the lock set. See Figure 27 for removal instructions.
PARTS:
Part NumberPart NameApplicationClassAvail.
D0AZ-6222050-JLock Set W/Attaching PartsMustang, T-Bird -AllAOK
D0AZ-6222050-KLock Set W/Attaching Parts
(Single Key System)
Ford - All Except 71BOK
D0AZ-7122052-JLock Set W/Attaching PartsFord-Model 71B
D0AZ-7122050-KLock Set W/Attaching Parts
(Single Key System )
Ford-Model 71BOK
D0OZ-7122050-ELock Set W/Attaching PartsFairlane - Model 71COK
D0AZ-6222050-ELock Set W/Attaching PartsMaverick - All After 12/1/69AOK
PRODUCTION CORRECTION: January 5, 1970
WARRANTY STATUS:
Reimbursable under the provisions of the Warranty and Policy Manual.
Operation: Use Operation 22050-A from Service Labor Times Standard Book for applicable car line.
DLR. CODING: Basic Part No. 22050 - Code No. 33
cron
