Article 2979 - Automatic Transmission - Reverse Clutch Pressure Plate Rebuilding
TSB #146 - August 7, 1970
SUPERSEDES ARTICLE 2279 TSB 138
(All Cars with C-6 - 1970)
The reverse clutch pack in a C6 built prior to 10-3-69 requires a six plate assembly, however, a C6 built after this date will no longer accommodate the six plate pack. Should it be necessary to order a new case, it will only accommodate the smaller clutch parts. Details for rebuilding are below.
PARTS:
DescriptionPart No.ClassAvail.
Trans. CaseC9AZ-7Q05-FOK
Trans. CaseC0OZ-7005-AOK
Trans. CaseD0AZ-7005-EAOK
Trans. CaseD0OZ-7005-BBOK
Pressure PlateC8MY-7B066-AOK
Pressure PlateC6AZ-7B066-LCBOK
Rebuilding the reverse clutch of a transmission built prior to 10-3-69, the following procedure should be used (see Figure 6):
When it is necessary to order the entire -7005- case and a case with a date prior to 10-3-69 is received, the above scheme is used but two additional steel plates must be used in four plate clutch packs. An instruction sheet included with the service parts indicates the proper number of clutches required. Transmissions built after 10-3-69 have the latest modifications to the case. These are built according to the following scheme (see Figure 7):
Case usage is as follows:
ModelNew CaseOld Case
1970 PGA, PGBDOAZ-7005-EC9AZ-7005-F
1970 PJA, PJB, PJC, PJDD0OZ-7005-CDOOZ-7005-A
Case No.Clutch PackPressure Plate No.Fiber PlatesSteel Plates
C9AZ-7005-F4 PlateC8MY-78066-A44
C9AZ-7005-F5 PlateC8MY-78066-A55
DOOZ-7005-A6 PlateC6AZ-7B066-A66
Case No.Reverse
Clutch Pack
D0AZ-7005-E4 PlateC8MY-7B066-A44
D0OZ-7005-C5 PlateC6AZ-7B066-C55
Figure 6 - Reverse Clutch Pack and Pressure Plate
Usage With New Service Cases
Part Nos. D0AP-700-G and D0OP-7005-N
Figure 7
cron
