(Mustang, Fairlane, Ford - 1969)
(THIS ARTICLE SUPERSEDES ARTICLE 1777, TSB #114)
Units exhibiting a slow crank after a one to ten minute hot soak should be handled as follows:
- 1. Check all starter, solenoid and battery connections for corrosion and tightness.
2. Check battery for proper charge, recharge if specific gravity is below 1.250.
3. Remove starter and lube the end plate bearings.
PARTS:
| Description | Number | Class | Avail. |
| Battery to Relay Cable | C2RZ-14300-H | A | OK |
| Relay to Starter Cable | C2RZ-14300-C | A | OK |
| Battery to Ground Cable | C2RZ-14300-E | A | OK |
WARRANTY STATUS: REIMBURSABLE
Operation: SP-11001-B-69 - Hard hot crank correction (steps 1-3)
Time: 0.4Hr.
Operation: SP-11001-B1-69 - Battery cable replacement
Time: All three cables - 0.4Hr.
DLR. CODING: Problem Code 82 - Basic Part No. 11001
