(1970 242 CID Dorset Diesel Engine)
The tapped threaded hole for the engine coolant sending unit in the L.H. front of the cylinder head has been changed from 1/8"—27 pipe thread to 3/8"—18. The currently released temperature sending unit can be used when replacement is required, however, a reducer bushing must be installed at that time.
PARTS:
| Part Number | Part Name | Class | Avail. |
| D0TZ-10884-A | Water Temp. Sending Unit (1/8"-27) | A | OK |
| C6DZ-10884-A | Water Temp. Sending Unit (3/8"-18) | A | OK |
| 357956-S | Reducer Bushing (3/8"-18 to 1/8"-27) | S | OK |
PRODUCTION CORRECTION: Effective in Ford of England production on November 1, 1969.
WARRANTY STATUS: Reimbursable within the provisions of the Warranty & Policy Manual.
Operation: 10884-A Time: 0.3 Hr.
DLR. CODING: Basic Part No. 10884 -Code 16
