(1966-1969 "W" Series)
For better sealing, install the service kit to rebuild the steering gear to the latest design level. Remove the steering gear from the truck and overhaul the steering gear using the overhaul procedures outlined in the 1969 Shop Manual, Volume I, Section 03-03-14. Additional shims should be ordered to obtain proper bearing preload with the new parts.
Shim:
- .005 Inches Thick - C1TT-3593-B
.010 Inches Thick - C1TT-3593-C
| Part Number | Part Name | Class | Avail. |
| C9HZ-3568-A | Steering Gear Conversion Kit | CG | OK |
PRODUCTION CORRECTION: 7-15-69
WARRANTY STATUS: Reimbursable within the provisions of the Warranty & Policy Manual.
Operation: SP-3504-A-70
Time 2.5 Hrs.
DLR. CODING: Basic Part No. 3504 - Defect Code 84
