(F-100, E-100/200, Bronco - 1969-70)
If rear axle housing misalignment is suspected, perform the checking procedure outlined below.
- 1. Raise the vehicle on any of the following (frame contact procedure is recommended). In all instances the rear axle is to be checked in an unloaded condition.
- Camber: -1/16" to +3/32"
- Toe-out: 0" to 1/4"
- a. Frame contact hoist.
b. Short jack-stands
c. Twin-post hoist with long jack stands.
3. Adjust both wheels so that the scribe marks are facing the front of the vehicle. Using a tape measure, measure the distance from the scribe mark on one tire to the scribe mark on the opposite tire and record this figure (front-of-tire reading).
4. Rotate the rear wheels so that the scribe marks are facing the rear of the vehicle, 180° from the original position. Again measure the distance between the scribe marks and record this figure (rear-of-tire reading).
5. The difference between the front-of-tire and rear-of-tire readings is the toe condition of the housing.
- EXAMPLE:
Front-of-tire reading - 62-3/16"
Rear-of-tire reading - 62-1/16"
Toe-Out - 2/16" (or 1/8")
6. Rotate the rear wheels so that the scribe marks are directly underneath the vehicle (on a frame contact hoist), or as near the bottom position as possible on a twin post hoist or jack stands. Again measure the distance between the scribe marks and record this figure (bottom-of tire-reading).
7. The difference between the bottom reading, obtained in Step 6, and the average of the front-of-tire and rear-of-tire readings, obtained in Steps 3 and 4, is the camber condition of the housing.
- EXAMPLE:
Average of front and rear reading - 62-2/16"
Bottom-of-tire reading - 62-2/16"
Difference - "0" Camber
8. If the results of the measurements taken do not fall into the following specifications, it will then be necessary to change the rear axle housing.
Tape Measure Specifications
