TSB #127 - November 21, 1969
(1970 Vehicles with C-4 Transmission)
Use Special Service Tool T70P-7902-A when checking the 1970 C-4 transmission turbine and stator end play or stator one way clutch torque.
A new essential Special Service Tool (adapter) is required for checking the converter hub turbine end play, stator end play and stator one way clutch torque on the 1970 C-4 transmission. The new adapter tool fits inside the new larger inner diameter of the turbine and locks tight when it is expanded. It will also work on past model C-4 transmission turbines. To function properly, this adapter tool must be used with the following available Special Service Tools:
T64L-7902-A and T59P-7902-C. THE NEW TOOL NUMBER IS T70P-7902-A. THE DEALER NET PRICE IS $3.07. IT CAN BE PURCHASED FROM OWATONNA TOOLS, INC., OWATONNA, MINN. 55060. Attn. Ford Order Desk.
