Article 1993 - Grounded Starter Cable
TSB #126 - November 7, 1969
(Maverick, 1970)
Mavericks with a no start condition should be checked for proper routing of cable from the starter to the starter relay. Units built in St. Thomas (Code X) may have this cable ground at the air cleaner air horn.
If the above condition is found, check the cable for damage, replace if necessary, and route, clipping the cable to the fender with a retaining strap, part number 376914-S.
PARTS
DESCRIPTIONNUMBERCLASSAVAIL.
Retainer Strap376914-SCOK
PRODUCTION CORRECTION: June 23, 1969
WARRANTY STATUS: REIMBURSABLE
Operation: SP-14431
Time: 0.2 Hr.
DLR. CODING: Basic Part Number 14431-A - Code No. 43
cron
