Replacing Radiator core support
Ferris95
Post by Ferris95 »
Looking to see what all you have to unbolt to get the radiator core support off. I have taken all the bolts off that I can see underneath and inside the wheel wells. Plus the grill and the headlight assembly. The 2 big bolts with the rubber bushings came out much easier than I thought it would. Maybe cause I kept soaking them with PB Blaster for days. Do I have to take off the bumper? Any bolts someone can think of that I may have missed? Is there instructions or a good YouTube Vid out there on it? I saw one from true Autrestomod Manic Mechanic, but he has the whole front end taken off, so that was no help. Also, is there anything else I should lok at replacing while I have all the stuff off? The support was the only thing I saw with rust holes on it, so that is why I’m replacing it.
68 F-250 Ranger Camper Special 390 FE
Retired Army
390FE1972
Re: Replacing Radiator core support
Post by 390FE1972 »
Here is a thread talking about removing the radiator core support: http://www.fordification.com/forum/view ... =7&t=58868
Here is a fordification diagram showing the front end parts and bolts: https://www.fordification.com/tech/imag ... e-6769.jpg
Regards :thup:
