No gears after hard acceleration
jgf100
Post by jgf100 »
Well boys, I f'n sent her a little too f'n hard!
So as the title says, I have no gears on my 70 F100, 302 with C4 automatic. Basically, I took off from a stop, floored it and I heard a loud bang and lost gears. Only thing I can do is put it in park. I had plenty of trans fluid.
1.) What is average amount I can expect to rebuild?, 2.) Is it worth it, should I swap for a 4- 5 speed? 3.) What auto w/ overdrive can I use?
'70 F100, 302 C4
cep62
Re: No gears after hard acceleration
Post by cep62 »
1ST make sure the drive shaft isn't spinning when it's in gear. to rule out a bad rearend.
and make sure you didn't break a u joint.
If this is a daily driver in traffic " I " wouldn't take out an automatic and put in a stick.
I believe an A O D can be made to work fairly simply .
jgf100
Post by jgf100 »
cep62 wrote: Fri Sep 16, 2022 7:05 pm 1ST make sure the drive shaft isn't spinning when it's in gear. to rule out a bad rearend.
Sorry, took me a minute to reply. I did check the drive shaft in gear, and it is not spinning. No broken u-joint. I removed flexplate access cover from bell housing and I didnt see anything obvious, no leaks, broken nuts, etc, gear shifter is connected to steering column. Aside from removing and opening trans, what else can I look at?
'70 F100, 302 C4
cep62
Post by cep62 »
jgf100 wrote: Wed Sep 21, 2022 12:49 pm what else can I look at?
The Yellow pages ! :D sorry
If you can put it in and out of park that means the linkage is working .
Pulling the pan and looking won't tell you much in my opinion . You might as well plan on pulling it out
and decide on a swap or rebuild. :2cents:
Generalee0527
Post by Generalee0527 »
I did that with mine back when I was 19. Sheared the yoke in the rear-end. I was sowi g out and dropped the clutch and POW. no more go. Seems that 31-10.5 mud tires have plenty of grip on pavement.
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
