High Oil Pressure (suddenly)
krogge
Post by krogge »
Have a 1972 390.
Has run great for years, all of a sudden oil pressure gauge is buried at highway speeds.
Any Ideas??
Dwell on the good stuff and you'll always be happy, dwell on the bad stuff and you'll always be angry. Be happy.
6Delta
Re: High Oil Pressure (suddenly)
Post by 6Delta »
What is the brand of gauge? Usually a problem is low pressure, either from a cheap gauge or faulty line (kinked if copper). I have never had a oil pump spring get stronger and increase pressure but maybe something is stuck in the pump making it "stiffer" and increasing the pressure. Otherwise I suggest a 2nd gauge to confirm what the other gauge reads.
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
fastEdsel
Post by fastEdsel »
I had the same thing happen to my '68 F100, it was the constant voltage regulator located behind the instrument cluster. Switched it out for a new one and that was my problem solved. Worth a try. :thup:
krogge
Post by krogge »
thanks to both of you :)
