Hello and greetings from Oregon!
My 72 F250 camper special has never been a daily driver because who has money for gas??
Seems the issue only occurs in town and during stop and start traffic. It’s a C6 and 360 motor.
Sometimes I have to drop it to low and then back into drive to make it shift into 2nd.
After scanning through the forum I see that it could be a vacuum leak.
Anybody else have this issue?
Transmission not shifting from 1st to second
- 72bumbee
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
Re: Transmission not shifting from 1st to second
Do you have the kickdown lever hooked up ?
That helps control the shift with throttle position.
- 72bumbee
I do not have the kick down rod installed. It is currently hanging on the wall in my shop. It was hooked up when I bought the truck but was removed when the shop rebuilt the transmission. Seems the couldn’t get it installed properly so they left it off.
It never did seem to make a difference when it was installed so I never even tried to reinstall it.
Mark Twain
Mark Twain
- The Bandit
Kickdown rod is only for kicking the trans down a gear so you can gain speed quickly to pass slower traffic. Your problem sounds like a sticking governor or problem with the modulator on the trans.
The governor of the C6 or fords in general are finicky anyway so I would have to guess that the governor is sticking.
Does it ever shift on it's own? You said a shop rebuilt the transmission. Did they put a shift kit in it and did they install the right modulator. Sometimes the shops are used to cars and will install the wrong modulator. It should have a black stripe, I am fairly certain.
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
71 Ranchero Squire
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
- 72bumbee
Usually when the truck first is driven it will shift fine. Then will start sticking after warmed up.
when i crawl under it, what will i be looking for?
I know where the kickdown rod should be connected on the carburetor and on the side of the transmission, so knowing that where would the modulator or governor be located?
Mark Twain
Mark Twain
