Swapping old 3 speed to C6
nau66
Post by nau66 »
I'm inheriting my dad's 68 F-100 SB 2WD. Current drivetrain is a 360 w/3-speed manual (floor shifter). I am trying to keep it period correct but plan to upgrade to a C6. I found a FE C6 core on Craigslist which does not appear to be from a 4x4. For ease of install, does it matter what tailshaft length it has? What other issues will need to be addressed for the swap?
pcmdub
Re: Swapping old 3 speed to C6
Post by pcmdub »
Hmm.. I am not a C6 expert, so keep searching. However, I DO know that there are SEVERAL C6 transmissions. Car ones have forward shifting valvebodies and so putting it in a truck makes the linkage backwards. Long beds have 2 piece drivelines and so the tailshaft of the C6 is different than a short (I think...again..no expert here). You may also want to look at the speedo cable and be sure they match up, some don't.
So ideally, you need a C6 out of a shortbed that had an FE in it. Then just have a drive shaft made to fit your truck. For shifting it, you can buy a Lokar floor shift to replace the stick but you may need to cut the transmission tunnel out anyway. If you have a removable hump, LMC carries the larger C6 hump to mount the shifter on.
Good luck
390FE1972
Post by 390FE1972 »
You also need to change out the steering column, if you plan on shifting at the column. You will need a automatic pedal assembly, and a neutral safety switch. Here is some data on automatic transmissions for our trucks: http://www.fordification.com/tech/trans ... trucks.htm
Regards :thup:
jpiercef
Post by jpiercef »
hello, i am currently trying to do the same to my 4x4. did you figure out what was needed? any advice you can share?
