Do I need this??
Ron_Hall
Do I need this??
Post by Ron_Hall »
Hey guys..
I'm missing the bar that runs from the hood latch to lower radiator support(pic). Not sure if I misplaced it or never had it. Do I even need it?
Thanks
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
Re: Do I need this??
Ron,
I had to go through my pics to confim but you're def gonna need it.
Looking at it is easy to see the structural bracing it provides for the hood latch.
I'm saying it could be found easily on a boneyard bump or even make a similar one from 1/4" heavy flat stock.
I thought I might have an image of the support of my 79', (thinking one from a dent might be the same even thought the hood latch is totally different) but I don't but I'd still glance at a dent support to confirm as it would be easier to find iin a boneyard. :wink:
pcmdub
Post by pcmdub »
Simple answer is yes. It holds onto the grill, latch, and if you add AC, it holds the Vintage Air condenser.
390FE1972
Post by 390FE1972 »
If you can't find one locally, try Tony's Ford Truck Parts, they were very helpful in helping me to find my rear gas tank strap for my aux gas tank.
https://www.facebook.com/pages/category ... 708918320/
Regards :drive:
Ron_Hall
Post by Ron_Hall »
basketcase0302 wrote:Ron,
Thanks Jeff, I'll start looking.
Ron
One owner...
Ron_Hall
Post by Ron_Hall »
pcmdub wrote:Simple answer is yes. It holds onto the grill, latch, and if you add AC, it holds the Vintage Air condenser.
Thanks pcmdub, I was afraid of that.
Ron
One owner...
Ron_Hall
Post by Ron_Hall »
390FE1972 wrote:If you can't find one locally, try Tony's Ford Truck Parts, they were very helpful in helping me to find my rear gas tank strap for my aux gas tank.
Regards :drive:
Thanks 390FE1972 , I did find one at Tony's! thanks
Ron
One owner...
