Wanted: 8-lug Dana 44 Parts
zainyD
Post by zainyD »
Hey gang, I was wondering if any of you might have some parts for a 8-lug Dana 44 axle I'm working on. The axle is out of a 78 F250.
Passenger side caliper bracket (can be from 76-79 Ford 250 8-lug Dana 44)
Big bearing spindles for 8-lug hub (need to be from a 78-79 Ford F250 with 8-lug outers)(5-bolt Ford pattern spindle)
Those are the essentials, but I can also use the following parts:
Both dual pistol calipers (driver & passenger side)(can be from 76-79 Ford 250 8-lug Dana 44)​
Both inner axle shafts (driver & passenger side)(can be from 76-79 Ford 250 8-lug Dana 44)
zainyD
Re: Wanted: 8-lug Dana 44 Parts
Post by zainyD »
Looks like I've been able to source the necessary parts. Thanks.
