WANTED: 67-79 F-100/150 4x4 coil spring towers
JoshT
Post by JoshT »
As title says I'm in serious need of a set of coil spring towers for a 67-79 F-100 4x4. Passenger side failed and the driver side is cracking in the same locations.
[image]1390[/image]
67-72 preferred, but I think I can make 73-79 work as well.
FLASH 1
Re: WANTED: 67-79 F-100/150 4x4 coil spring towers
Post by FLASH 1 »
if nobody jumps in next few days we do have Good Used Ones sitting on the shelf, like always we want other members that might have in their private stash go first , not like others I have seen here so give it a few days and if not send me a PM
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
JoshT
Post by JoshT »
Thanks Tom! I've actually got a member of FTE that is supposed to be getting me a set. If that falls through, I'll be in touch.
FLASH 1
Post by FLASH 1 »
No problem, like I said I let members go first, and since a business rather do it like that, Good Luck
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
JoshT
Post by JoshT »
FLASH 1 wrote:if nobody jumps in next few days we do have Good Used Ones sitting on the shelf, like always we want other members that might have in their private stash go first , not like others I have seen here so give it a few days and if not send me a PM
Tom, you say that you've got the 4x4 coil spring towers sitting on the shelf? I'll be sending you a PM shortly.
FLASH 1
Post by FLASH 1 »
Josh got it will know over weekend the price,, Tom
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
