brake pressure differential valve
67 short box
Post by 67 short box »
after an ill fated attempt to install front disc, I have all drums on now. the brake light is now on and I forgot what to do to get it off. I know the valve works because I had it off once and fixed the piston. 67 thanks....
390FE1972
Re: brake pressure differential valve
Post by 390FE1972 »
KulpFarm
Post by KulpFarm »
I believe once you re-center to piston in the valve, it will go off.
67 short box
yessir. just took the brake line off and the bushing and used a rat tail file and pushed it back down, off now
thanks everyone
