PaPa's 69 F100 Explorer Coyote 10R80 swap
- Venomous duck
Re: PaPa's 69 F100 Explorer
These are the spindles from the 75. The first thing I did was media blast and powdercoat them. Next the king pins needed to be replaced. I called several machine shops and was turned down every time. So I decided to do it myself. I lost my before pics of the spindles but they were very rusty as you would expect. This is showing the removal of the bushings.
Last edited by Venomous duck on Sun Nov 27, 2022 6:24 pm, edited 2 times in total.
- Venomous duck
Here is the Moog kit that I used
- Venomous duck
I was able to find the reamer and pilot on ebay. Made by Chadwick & Trefethen. G HSS Reamer 21570 (adjustable) and G Screw on Pilot 07570. Keep in mind that Ford used a couple of different sizes of king pins and require different reamers.
- Venomous duck
After knocking out the old bushings I needed to press in the new ones. I tried to use my HF press but could not get them to go in straight.
- Venomous duck
I then used my Ball joint/u joint press. This worked well.
- Venomous duck
I then proceeded with the reamer. Using lots of cutting oil and going slowly I was able to get a good fit. This turned out to be pretty easy. Getting the old pins out was the hard part.
Last edited by Venomous duck on Thu Aug 29, 2019 7:53 pm, edited 2 times in total.
- sargentrs
Looking good! Thanks for posting the king pin bushing install!
- hfdco4
Nice work. Now that you are a pro you should due this for other people.
FE390PC
FE390PC
- Venomous duck
That sounds too much like work
- Venomous duck
This is the point where I decided to take a really good at the rust prone areas. I pulled the floor mat.
Last edited by Venomous duck on Thu Aug 29, 2019 8:02 pm, edited 2 times in total.
- Venomous duck
Driver side floor pan
- Venomous duck
Driver floor pan and kick panel.
- Venomous duck
Passenger Side
- sargentrs
I've seen lots worse.
- Venomous duck
Yes, this is minor compared to what others have had to deal with. I am amazed at what others on this site have accomplished. I am lucky to have such a solid truck.
