"C" bushings on the front diff
Hi can anyone tell me if im replacing the "C" bushings on the front diff. Do i need to use a spring compressor, thanks
Re: "C" bushings on the front diff
Absolutely not, just set the truck up high with jackstands under the frame, put a floor jack under the front axle and drop her down.
1967 F-100 4x4 custom cab.
You might want to loosen the front shocks.
