How do you protect your engine/parts from theft?
- 1968flareside
My buddy had a chain and padlock on his 72. I just can't remember what/how/where he had it hooked up. I'm worried about the msd box and carb specifically. That is for quick, spontaneous thieves.
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
- 460 crew
I was thinking a cable with a llock looped through the hood somewhere and back down and locked wrapped around the frame, so I could unlock it right under the bumper?
- Joe Kriston
re: How do you protect your engine/parts from theft?
The p.o. of my truck concocted something like 460 Crew described---and it was the first thing I removed....If I didn't throw it out you can have it---I keep my truck in the garage ...I can also send you my bad hood hinges with the worn springs--the ones that hold the hood up low enough so the thieves will bang their head on the latch every time they try to pull something out from under the hood....
you can get a hood lock. I have one. I will see if I can get a picture of it. It goes around the latch and around valence area, I forget exacly how. Its very small, just a solid bar that is bent.
When the going gets tough, your doing something right.
I "threaded" a length of chain through the front of the hood channel. Then I lower the hood and bring the chain through the top of the latch hole and padlock it to the front of the center support bracket of the grill. Make sense? Maybe not, but it works fine as long as you don't have the 70 grill.
- j41385
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
- pat67shorty
When Mine had to sit out side during my bronco's V8 swap... I took a cable for locking up a bike, ran it through the hood bracing, down and looped around the frame behind the bumper. Then pad locked it.
I've been meaning to get one of those 12ga anti theft devices though...
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
I run a pretty good illusion of running on steam power
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
- surubet
Here's what I did years and years ago, although my lawyer said I could be sued. I super glued straight razor blades under the lip of the hood. It only took one week for the blood trail to show up and I didn't have anymore trouble after that and removed the blades with acetone. I even saw the neighbor from two blocks up the street with all the bandages on his fingers.
Naturally I had to remember not to cut myself to ribbons that whole time too.
1970 Ranger XLT F250 Camper Special, 2X4, 360, Factory A/C, 2 tone in greens.
- binder56jd
chain & padlock jd
now serving #235
now serving #235
- DuckRyder
:twisted:
- binder56jd
S-man- that's a good idea!
DR- that'll work although i prefer the short barrel 12 ga w/ seven in the tube for up close& personal :twisted: :twisted: :twisted:
jd
jd
now serving #235
now serving #235
- LilJack
Tie a large Pit Bull to the truck :twisted:
My Teardrop camper
http://www.wcscrc.net/teardrop.htm
72 F100 Custom
http://www.fordification.com/galleries/ ... ?cat=10294
72 F100 Custom
- binder56jd
Get one of those rubber snakes and attach it in a likely spot :twisted: :twisted: :twisted: jd
now serving #235
now serving #235
