1972 Ford F100 Project.
Re: 1972 Ford F100 Project.
Put new bushings in the drivers side I-beam and installed I-beam.
- popeyes71
Looking good!
-Popeye-
1971 F-250 4x4 Highboy
- hfdco4
Great PROGRESS!
FE390PC
FE390PC
Both I-beam bushings are in and the the I-beams are back on the truck. Waiting for the new Kingpins and reamer to arrive. It will be awhile till they arrive, having to cross the border from the States to Canada. In the meanwhile I will clean up, sandblast and paint the brake backing plates and spindles.
- hdman90
Wow, you are crusing through this project! Can't wait to see the reassembly and see this thing look like a truck again! Keep up the steady work!
[quote="emeraldcoupe"]looking good. we could be twins
They sure are close to being twins, nice job on yours.
- Manny
Looking good. That old frame cleaned up mighty nice!!
- popeyes71
Very nice, she is looking good!
-Popeye-
For a change of pace, I built the cab dolly for the truck.
- Manny
I need a dolly like that! Cab coming off soon?
I will probably take the cab off next spring, that is when I plan to do the panel work on the cab. My shop is not heated for the winter, it gets a bit costly when the temperature drops to -30C to -40C in the winter.Manny wrote:I need a dolly like that! Cab coming off soon?
- hdman90
Do you plan to reassemble and get it running in the mean time? Or will the project be on hold until spring??North56 wrote:I will probably take the cab off next spring, that is when I plan to do the panel work on the cab. My shop is not heated for the winter, it gets a bit costly when the temperature drops to -30C to -40C in the winter.Manny wrote:I need a dolly like that! Cab coming off soon?
The project will probably be on hold till the spring. Will spend the winter getting body panels together for next spring. I want to price out rebuilt 302 engines also, see if I will do it myself or get a shop to do it.hdman90 wrote:Do you plan to reassemble and get it running in the mean time? Or will the project be on hold until spring??North56 wrote:I will probably take the cab off next spring, that is when I plan to do the panel work on the cab. My shop is not heated for the winter, it gets a bit costly when the temperature drops to -30C to -40C in the winter.Manny wrote:I need a dolly like that! Cab coming off soon?
Sandblasted and painted drivers side spindle,brake drum and associated parts.
