Some brake issues
TxCamperSpecial
Some brake issues
Post by TxCamperSpecial »
Tell me what you brake experts think. The brake pedal is rock solid. When you step on it, the pedal only goes down about 1 inch and slowing is very sluggish. I haven't had this truck long so I haven't done the basics yet. First I was going to bleed the brakes and if that didn't help, replace the power booster. Any other ideas or advice? Thanks.
1972 F250 Camper Special 360ci 4sp
1979 Ford Bronco 400ci
qman
Post by qman »
Mine did that cause one of the front cylinders was leaking and I only had rear brakes. I almost couldn't hold the truck from moving forward at idle with all my might. So bleeding will help it but if you have the same problem I did then you'll have to fix the leak.
72 F100 2wd 360 C6 Custom w/factory PS.
TxCamperSpecial
re: Some brake issues
Never thought of that, thanks. When I'm bleeding them, I'll be looking for leaks. Thanks.
jor
Post by jor »
If the pedal is solid, I wouldn't think bleeding will help. I had the same problem some time ago with my 67. It turned out that I wasn't supplying enough vacuum to the booster. Once that problem was fixed, the brakes worked normally. Make sure you have a dedicated vacuum source for the booster and check the booster for leakage.
jor
binder56jd
Post by binder56jd »
i concur w/ jor- sounds like booster issue- jd
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
or maybe a frozen/ stuck wheels cylinders. and you can check for leaking if you push real hard on the brakes and park it over night. then in the morning look underneath it to see if there is any brake fuild on the lower inside of the tire.
ToughOldFord
Post by ToughOldFord »
Make sure none of your brake lines are crushed or kinked.
Jake11
Post by Jake11 »
The little pistons get stuck. You can have a good pedal, and no brakes!
surubet
Post by surubet »
Check for overheated and glazed pads/shoes too. I've scruffed them up (with crocus cloth) and taken the shine off and gotten better braking before. Watch out for asbestos pads and shoes though. Getting them wet with water will keep asbestos fibers from getting into your lungs.
1970 Ranger XLT F250 Camper Special, 2X4, 360, Factory A/C, 2 tone in greens.
