Should I replace or rebuild? Steering gear box
- Godspeed128
Is this A typical 1967 F100 steering gearbox? I’m doing a restoration of this old truck Should I replace it rebuuld
dYou do not have the required permissions to view the files attached to this post.
Re: Should I replace or rebuild? Steering gear box
It depends on ones mechanical ability. Parts for it might be a challenge to locate.
1967 F-100 4x4 custom cab.
- jzjames
Would just get a rebuilt one and be done with it.
- Godspeed128
I have a doner truck that may have a power steering setup in it if so I will most likely use it
Mr Godspeed, either way seems good.
I like your "name'.
I like your "name'.
I have a perfect manual steering gear that I removed from my 25,000 mile 69 to install PS. My Dad bought this truck new and I've owned it for 42 years so this is not some worn out junkyard part. Let me know if you're interested. Has the pitman arm already installed.
