Man! Those frontend busings did not want to come out! It took well over 150lbs pressure with the press to get them out. The old ones are out and the new are in. Time to to put brakes/ frontend on, then trans, then engine. Will have pics soon.
Thanks.
Got front bushings pressed in
- blue68
re: Got front bushings pressed in
You going with stock rubber replacements?
- blue68
I went with stock rubber as well, but I used poly on radius arms.
When the going gets tough, your doing something right.
