Clutch Pedal Repair
Clutch Pedal Repair
Well, Here's a new one for me. I noticed that the clutch kept coming out of adjustment over a period of every 3 weeks. I checked all my linkages and reset the clutch adjuster. Finally, one day I'm trying to get back home and step on the clutch only to have it break off of it's shaft and land on the floor. I was able to disassemble the rest of the clutch shaft and had my wife pick up. I ended up rewelding the shaft back where it belongs and reheatreating the weld. I returned next morning, reassembled my truck and then drove it home. I'm currently trying to recreate the shaft out of a grade 8 socket head bolt. If any one has ever experience this problem before I'd like to know. I'd also welcome any advise or criticism as long as it's helpful.
- fireguywtc
Re: Clutch Pedal Repair
Bill
2024 F350 CCSB, darkened bronze
Welcome from Michigan.
I've seen a couple of clutch linkage failures.
Once repaired they'll last the life of the truck.
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
WElcome From AZ
Posting over in the proper category will probably get you some good replies. Not all the members look here.
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
