Widened '60's hubcaps for trucks with '70's power disc brakes
swbeck18
Re: Widened '60's hubcaps for trucks with '70's power disc brakes
Post by swbeck18 »
Hi 69timemachine
Just found this post after joining the group last year. I really like the removal tool you made and I'm wondering if you want to market them? Just kidding but I've had a fun time removing the caps from my 69 250. I resorted to using a cheap pair of harbor freight angled needle nose pliers the first time to pop them off. Looking for something a little more permanent if someone has any ideas?
1969 F250 Camper Special, 360
2012 F150 4x4 Lariat, 3.5 EcoBoost
69timemachine
Post by 69timemachine »
If your wheels are stock width, you should be able to use a jumbo flathead screwdriver, a tire spoon, or an angled pry bar. Any tool store will have those. Maybe add a piece of rubber hose around the shank so it doesn't chip your paint.
If you're running extra wide wheels with the caps recessed way up in there, then building a tool like the one I did will be your best option.
Jason
'06 Mustang GT 5-speed
